87 vfr 700 spark unit
Discussion in '1st & 2nd Generation 1983-1989' started by 87vfr, Jul 3, 2014.
  1. 87vfr
    87vfr New Member
    Hey guys I have had some trouble in the past with my bike and have been helped out quite a bit .. thank you!! I need to obtain a 87 vfr 700 spark unit because im having fuel pump issues .. and well the spark unit has power to the fuel pump.. any help on where to find the spark unit because im sure im way over looking it
    You'd probably have easy success just by installing a bypass wire at the plug going to the fuel pump relay. If relay has gone bad (a frequent problem) new CDI won't fix anything.
