'86 VFR Brake Rotor Question
Discussion in '1st & 2nd Generation 1983-1989' started by Guest, Jun 18, 2003.
  1. Guest
    Guest Guest
    I need a set of rotors for my '86 VFR700. What other models (if any) used the same rotors? I heard the '87-'90 CBR600 Hurricane uses the same rotors. Anyone know if that is correct? Any help would be appreciated.
    Regards,
    Ed
  2. Guest
    Guest Guest
    Hey Ed I have two 87's and one has the CBR f2 rotors on it and I have a spare set for the other. Just went out and held them up to the unchanged bike and tho they have a slightly different appearance the size and bolt pattern are exactly the same. Don't exactly know which years are the CBR f2 tho. I've heard of guys gettin em as low as 60 for the pair. If ya can't find rotors I'm sellin my VFR... I'm keepin the spare rotors tho.
  3. keny
    keny New Member
    Finland
    city of Karjaa, Finland North Europe
    The 86-87 vfr 700/750f got the same rotor as cbr600 88-94.
  4. waldrm
    waldrm New Member
    SE North Carolina
    They are right; don't let somebody sell you '90-'93 VFR rotors claiming they are the same as the F2.  I have seen them listed that way on eBay.  The early VFR and CBR600F1/F2 rotors are 280mm while the '90-'93 VFR rotors are 296mm.  Can't use F3 and later rotors as the bolt pattern is different (smaller) for the floating rotors.
