86 VFR 750 Swingarm Upgrade, and Fork upgrade.
Discussion in 'Mechanics Garage' started by Fanatical Performance, Jul 9, 2011.
  1. Fanatical Performance
    Fanatical Performance New Member
    Wausau WI
    I want to upgrade my swingarm, and fork setup. What is the easiest way to do both? I would like to run a 180 tire in the back. I would like to be able to mount my fuse box and gauges to look stock. I would also need to buy the parts to do this. Any help would be appreciated.
  2. TOE CUTTER
    The easiest? Buy an newer bike. Not trying to be a jerk but you are not going to get you money back oot of it and your talking aboot two separate projects that will get expensive.
  3. rc24rc51
    rc24rc51 New Member
    Liberty SC
    Installing a complete CBR F2- F3 front end would be your best bet for a swap. What's wrong with the swingarm? A 160-170-180 rear tire will go in there but the 180 will require an offset countershaft sprocket. Don't know if a mid 90's CBR900 swinger can be made to fit. But a upgraded rear shock would work wonders for your bike.
  4. fatso1277
    fatso1277 New Member
    South Suburb IL.
    yeah as said before the F2-F3 is the best and easiest swap to do for front and back...the swingarm can be a bit more tricky...it is possible but a lot of work(Right Toecutter!!)..u can search chuck crites BRACED SWINGARM...
  5. Fanatical Performance
    Wausau WI
    F3 Upgrade
    I would like to do the F3 conversion front and back. Who has parts?
  6. Fanatical Performance
    Wausau WI
    F3 Upgrades
    I don't care about getting my money back either. This is my 4th 86 VFR, and my first 750. I plan on keeping it for life. Any help or direction to threads would be helpful.
  7. slowbird
    slowbird Member
    Toronto, Ontario.
    A 180? Why you need such a wide tire?
    My 4th gen doesn't even have a 180.
  8. rc24rc51
    rc24rc51 New Member
    Liberty SC
    180/55/17 is the stock size on a 4th gen.
  9. Fanatical Performance
    Wausau WI
    Swingarm and wheel upgrade
    Rc24Rc51 it looks like you have done the F2 or F3 conversion? Those are CBR wheels correct? How did you do your swap?
  10. slowbird
    slowbird Member
    Toronto, Ontario.
    Incorrect.
    4th gen is a 170/60/17
  11. fatso1277
    South Suburb IL.
    naw that just a picture of bubba shuberts bike...u can go to hondavfr.org for detailed instructions on how to do swap for F2/F3 swap. Ebay is going to be your best bet for parts for the swap. the front is pretty straight forward...Just need someone to do some machining for u. Just remember for rear, its probably EASIER to use F2/F3 rear caliper bracket than having VFRS cut and rewelded to fit CBR Rotor. Search Supertex Build for details on that. Just have to find Spacers that work.
  12. rc24rc51
    rc24rc51 New Member
    Liberty SC
    right you are Slo. I meant 3rd. gen. The 8 spoker was a 5.5in I believe.
  13. slowbird
    slowbird Member
    Toronto, Ontario.
    What size are people running on the 2nd gen with the F2 wheel swap? 150? 160?
    Yes sir. The 4th gen went down to a 5" rim...then (I think) it went back up to a 5.5" for the 5th gen.
  14. rc24rc51
    rc24rc51 New Member
    Liberty SC
    I run a 160/60-17 on mine.
  15. rc24rc51
    rc24rc51 New Member
    Liberty SC
    personally I think a 160 is plenty of tire for that bike.
  16. slowbird
    slowbird Member
    Toronto, Ontario.
    +1. I second that.
    180 is overkill.
  17. fredsncoma
    fredsncoma New Member
    Gardnerville, Nevada, United States
    Same with mine. I think this is probably the most economical upgrade you can do and the tires work great. Wheels look much sweeter too.
  18. Davis5g
    Davis5g New Member
    Pittsburgh, PA
    You have to be aware that putting on a wider rear tire will make the bike turn slower...
  19. rc24rc51
    rc24rc51 New Member
    Liberty SC
    you also have to add some ride height to the rear to compensate for the smaller 17in. wheel.
  20. matt1986vf500f
    matt1986vf500f New Member
    Lula, Georgia, United States
    also add the power ratio to it a 180 is alot of tire no doubt about that that much larger of a tire the bike will turn slow and with the add friction from the larger tire is going to slow the bike down....just my two cents
