86 vf500f idle problem
Discussion in '1st & 2nd Generation 1983-1989' started by chr0n0s21, Jun 15, 2009.
  1. chr0n0s21
    chr0n0s21 New Member
    So i like to think of myself as pretty mechanically inclined. Done all my own repairs on everything i owned.. I just did the valves on my interceptor. Checked the valve lash like 5 times to make sure it was right. everything looked good. put it all back together.. Ran like a champ.. tears in my eyes to how good it sounded. let run for another 5 mins to warm up for a test ride. with the choke full on the idle started to drop. then die.. would kinda run. but only with choke on. i used .006 feeler gauge as the book called for. im at a loss.. i need my bike back as it is my only transportation. oh i also checked the spark and its all good.
    let me know your ideas.. thanks
    Frank
  2. masonv45
    masonv45 New Member
    If it will only run with the choke on, the fuel mixture is too lean without the choke.
    Usually it's the carb boots causing problems. You can try turning the pilot screws out 1 turn. But the bike should run fine with them at stock settings.
  3. gunnarf06
    gunnarf06 New Member
    Hafnarfjordur
    Heard about this before
    Hey
    There was a guy witch had this problem he found out that his bike didn“t run on all cylinders.
    Best regards
    Gunnar
  4. squirrelman
    never use ANY choke if the bike will run without it........ and if it won't you need a carb cleaning.
    IT's easy to flood the sparkplugs with excess fuel by using choke when not necessary.
  5. chr0n0s21
    All fixed!!
    Ended up bein the carbs needed to be cleaned.. and bad.. got it all back together and she runs like a top! love this little bike. Its my first and its been a blast! gettin time for a new one now tho.. hahaha! dont know if ill get rid of this one tho! Thanks again for all the replys and advice. And Jim Daughtery.. thank you very much. i did the steps at u did and it came out perfect! thanks again all!!
    Frank
