86 vf500 front sprocket
Discussion in '1st & 2nd Generation 1983-1989' started by vegita65, Feb 10, 2009.
  1. vegita65
    vegita65 New Member
    I need one to fit my 500, but I want to go to a 520 chain since I have a crud load of new 520 rear sprockets to fit the 600 hurrican rear wheel.
    And Id like to get a nice 520 oring chain on it.
    I called a couple local shops but they couldnt find anything in 520.
    What other modern bikes use the same front sprocket.
  2. JamieDaugherty
    JamieDaugherty New Member
    Fort Wayne, IN
    None.
    You can always machine down a 530 sprocket. The only difference is the width. In this case it would go down to 0.250in (20/80ths) instead of 0.375in (30/80ths) thick.
  3. matt1986vf500f
    matt1986vf500f New Member
    Lula, Georgia, United States
    why do you want to use a 520 chain to begin with?
  4. vegita65
    vegita65 New Member
    Becouse it lighter, and there is no need for a 530 chain. My 07 gsxr750 has on a 520 conversion and Ive had not one problem.
    So Lighter, less drag, Ill have a but load of gearing options.
  5. JamieDaugherty
    Fort Wayne, IN
    Yes, it does make a noticeable difference. Gearing options? It sounds like you are having a lot of difficulty in that area!
  6. vegita65
    vegita65 New Member
    What I meant by that is that I have like 6 or so different rear gears.
    I plan on doing a few track days. So itll be nice to have some options.
    Ill just have my dad machine one down.
  7. midias
    midias New Member
    Rochester NY
  8. JamieDaugherty
    Fort Wayne, IN
    Unfortunately that's a totally different animal than the VF500F.
  9. midias
    midias New Member
    Rochester NY
    ^ yea but they did a custom job for my rear and worked with me to find the front so they may be willing to help him find a 500f front. The never listed a kit for my 86 but they did help me put one together.
