86 vf 500 80000 kms! what to do?
Discussion in '1st & 2nd Generation 1983-1989' started by xxxbrandonxxx, Oct 6, 2009.
  1. xxxbrandonxxx
    xxxbrandonxxx New Member
    Burlington
    i recently bought this bike with 75000ish kms this year ive kept up with oil changes and some fluids the bike seems to be running good now that i took the gas tank off and shook out the rust and rust coated it what other things should i look at to replace or help maintain the bike? its all stock as well
    any advice would be appreciated it runs pretty good only problem i seem to have is 6th gear runs like ass 5th gear get the bike up to 140 easilly and 150 pushing it
    pop it into 6th and it literally drops down to 120 and maxes out at 140 after along time at full throttle would rust in my carbs cause this? and what else can i do to keep it maintained?
    -and finally where can i buy a after market windscreen for a reasonable price? or can i sand and paint the stock one?
  2. TRX250R
    TRX250R New Member
    R.I.
    I sanded and painted mine, came out good. I used a black Fusion plastic paint.
  3. slowbird
    slowbird Member
    Toronto, Ontario.
    80,000kms?!?!!? :eek: Holy shit guy.....that's crazy.
    Your 6th gear problem sounds odd. Does it rev freely throughout the RPM ranges in every other gear?
    For maintenance make sure your chain and Sprockets are in good shape.
    (I have a brand new Rear sprocket on a wheel with a brand new tire if you wanna talk buying it off me....since you're soo close)
    Maybe think about getting the carbs reuilt and a valve clearance check.
    (I know a guy in Stoufville who specializes in our bikes) :thumbsup:
  4. xxxbrandonxxx
    Burlington
    yah i know him too i think its him atleast. He came down with a re-done set of carbs and installed them to proper levels at 77000 cuz mine were done!
    ill send u a message on gta since im on there alot more!
  5. xxxbrandonxxx
    Burlington
    and if i remember correctly my lower 3 gears all rev to the red line and each gear after that kinda decreases 4 and 5th stop at around 10000 but i have never tried to full throttle it to the redline in those gears just because there is no point, but 6th gear i dont think i can get over 7000 rpms
  6. slowbird
    slowbird Member
    Toronto, Ontario.
    Do you have the stock gearing?
    15 tooth Front Sprocket 43 rear
  7. xxxbrandonxxx
    Burlington
    ill count the rear tomorrow! too late now and we can go from there
  8. Rollin_Again
    Rollin_Again Member
    Duluth, GA
    You can't possibly be talking about miles per hour? :confused:
    I find it a little hard to believe that a 23 year old VF500 can push 150mph in 5th Gear. That is unless you are using Slick50 like the rest of us :biggrin:
    Regards,
    Rollin
  9. slowbird
    slowbird Member
    Toronto, Ontario.
    No he means KM/H.
    150km/h = 94mph
    That's what we go by up here in Canada
  10. slowbird
    slowbird Member
    Toronto, Ontario.
    Hmmmm.....this just popped out at me when I read it.
    My bike is doing 130 km/h at 7,000rpm in 6th gear.
  11. matt1986vf500f
    matt1986vf500f New Member
    Lula, Georgia, United States
    you didnt know these bikes could do 150 dumbass :biggrin:
  12. Rollin_Again
    Rollin_Again Member
    Duluth, GA
    I know how fast your bike goes Matt because I was able to pace some of the parts that were falling off your bike :biggrin:
    Regards,
    Rollin
  13. matt1986vf500f
    damn i was hauling ass that day :biggrin:
  14. xxxbrandonxxx
    Burlington
    but does your bike stop there? wont go any higher in rpm's? my 5th gear gets me a better top speed its wierd
  15. xtravbx
    xtravbx New Member
    Cleveland, OH
    It may not have anything to do w/ your transmission. It could be your motor is on the tired side and not able to produce the power needed to push the bike faster in 6th gear. Obviously 6th is a larger gear - and it does need more power to increase its rotational speed. I imagine it can maintain a steady speed in that gear, just cannot INCREASE very well?
    Or does it feel like youre hitting a rev limiter? Or does it feel like it's just dying and has no more go?
  16. xxxbrandonxxx
    Burlington
    yah it pretty much maintains that speed fine i just cant increase the speed(i dont mind its more then i need) just curious thats all
  17. slowbird
    slowbird Member
    Toronto, Ontario.
    You think it's the motor? If he's punching it through the gears and he gets to the top of fifth and switches to 6th and it suddenly falls on it's face......sounds quite odd.
    No...mine will keep on going.....odd.
  18. Bubba Zanetti
    Bubba Zanetti Member
    Delaware
    I agree with the "tired" motor.
    A friend has a 2006 R6 track bike with close to 15,000 track miles and he was just stating the same syptoms. (He's in Advanced group, so his engine gets a work out).
    Bike runs fine, but in top gear she just doesn't have what she used to. Bike doesn't leak oil, blow smoke, nothing. Riders at the track more knowledgable than me all came to consensus on the issue.
    This old 500 sounds similar. Alot of miles but she still runs. Do your regular maintance and don't worry about it...you are on the street.
    BZ
  19. xtravbx
    xtravbx New Member
    Cleveland, OH
    The reason I think that is that he can't redline 5th or 6th.
  20. slowbird
    slowbird Member
    Toronto, Ontario.
    Well Brandon...I can always sell you my bike.
