86-87 VFR R/W/B owners. I need measurements!
Discussion in '1st & 2nd Generation 1983-1989' started by vfrf2, Sep 24, 2009.
  1. vfrf2
    vfrf2 New Member
    Manassas, VA
    I'm painting my 87 VFR r/w/b. I'm getting ready to paint the top portion of my gas tank and front fairing and need some measurements. Not knowing where the white stops and blue starts, I was wondering if someone who has one could take a couple of measurements for me so I don't screw this up?
    I'd like to know the measurements from the bottom of the tank where the red mark is, to where white ends and blue paint starts. I really don't know to go about getting an accurate measurement on the front of the tank where the blue starts. If anyone can find a good starting point for my measurement there I'm open to that information as well.
    Also, on the front fairing...if you could measure the points I have marked in my pic it would be helpful as well.
    Crap, can't upload pics for some reason right now!
  2. TOE CUTTER
    Paint
    I will measure it for you when I get home tonight. The factory did a rough job of it and hid it with the decals , so exact start and stop of white and blue is not that important.:thumbsup:
  3. vfrf2
    vfrf2 New Member
    Manassas, VA
    TC...I appreciate it.
    I think I'm going to be OK on the front fairing. The decal is pretty easy to use as a guide. The tank is the only thing that I'm probably going to need a measurement on.
  4. TOE CUTTER
    Tale of the tape
    This is with the tape tight notfollowing the curve of the tank.181 millimeters
    This is 176millimeters tape tight.I know the picture does not look that way but I only have so many hands. Sorry for the poor reference but it is tough to pick out a good point to measure.Please contact me if other points to measure are needed.:thumbsup:
  5. TOE CUTTER
    I'm fired
    176mm pic
  6. TOE CUTTER
    Trust me
    I know pics suck but trust me I measured and had to let go of the tape for pic.Those are the point i measured off of.:twitch:
  7. captb
    captb New Member
    Can you measure the red stripe on the tank, this helps alot. I'm doing mine all paint so I don't have the decals to go by. thanx
