86 750 carb swap
Discussion in '1st & 2nd Generation 1983-1989' started by josh383, Nov 4, 2016.
  1. josh383
    josh383 New Member
    Michigan
    Has anyone swapped in a set of 36mm 3rd gen carbs on a 2nd gen bike?
    Why ??
    Stock engine needs stock carbs. :rolleyes:
  3. josh383
    josh383 New Member
    Michigan
    Not quite stock anymore, 3mm overbore with 12.5:1 pistons, megacycle cams, 1mm oversize intake valves, ported heads, rotating parts micro finished and low friction coating applied, 1 3/4" 4-2-1 titanium exhaust.
    Just wondered if anybody has built anything and used the 36mm set, I'm leaning towards bustin down a rack of 38mm from a 900rr and using them.
  4. squirrelman
    Holy crapola ! You paid twice as much for that engine work than i paid for my first VFR back in 1990 fo sho. :numbness:
  5. josh383
    josh383 New Member
    Michigan
    Well, I only paid $400 for the ol girl, so I'll still have less into er than a new bike. I'm also swapping the front end, bracing the swingarm, F2 rear wheel, and have a fox twin clicker Jamie D rebuilt for me. I'm going to be importing her into a country that taxes anything over 200cc 100% of the current bb value, so this way I'll have a bike setup exactly how I want and not have to worry about wasting a bunch of money on taxes. Not to mention that for me, there's just no substitute for the sound of that V4 when you put the throttle to er
