86 700 Engine into an 84 Chassis?
Discussion in '1st & 2nd Generation 1983-1989' started by vintgvfr, Aug 4, 2008.
  1. vintgvfr
    vintgvfr New Member
    Hi guys, like the title says I'm wondering whether a 1986 VFR700 gear driven cam motor will bolt into a 1984 VF700F chassis. I realize this is not the ideal way to go and I would be better with the 86 aluminum chassis, but I am interested in doing this project on a budget and this is what I've got available to me: a decent 1984 chassis with all the body work/seat/tank etc. and I have access to a 1986 700 VFR motor/carbs/electrical/airbox/headers with only 9000 miles that runs very well.
    Is the 86 engine is a bolt in to the 84? Has anybody out there done this swap that can offer any advice? Thanks in advance.
    Kris
  2. JamieDaugherty
    JamieDaugherty New Member
    Fort Wayne, IN
    Nope, not a bolt-in. In fact, it would take quite a bit of work to make it fit. That said, nothing is impossible, if you can fabricate and machine parts you should be able to make it work. I think the hardest part would be trying to get the chain in the correct spot.
