85 vf1000r help
Discussion in 'Mechanics Garage' started by ozzy67, Jun 26, 2012.
  1. ozzy67
    ozzy67 New Member
    Got the bike about 2weeks ago, now I have issues. When first starting out to ride I got threw all the gears riding normal,down shift once then when coming to slow down try to downshift from 4th to 3rd it will not let me
  2. TOE CUTTER
    Is the lever stuck or does travel it's normal length and not shift?
  3. GreyVF750F
    GreyVF750F Member
    West of Cleveland Ohio
    If you mover the shifter up or down and it stays in the same gear and doesn't shift could be an easy fix. There is a small spring on the spindle gearshift mechanism that breaks. When it does it won't have tention on the arm to turn the shift drum. There was a recall on them years ago. Ask me how I know............
    Look at it here. part #17: Honda | Suzuki | Yamaha | Can-Am | Ski-Doo | Sea-Doo | Motorcycle | ATV | Scooter | Parts | Accessories
    It's behind the right side cover, behind clutch basket area.
