84vf700 fans not working
Discussion in '1st & 2nd Generation 1983-1989' started by craveman85, Jun 7, 2010.
  1. craveman85
    craveman85 New Member
    st. johnsville ny
    radiator fans wont kick in but turn freely. i was thinking of hardwiring them to the main ignition feed so they are always running when the bike is on. suggestions?
  2. jeef84
    jeef84 New Member
    Fullerton, CA
    In my experience (with autos) having the fan on all the time leads to overcooling, which isn't what you want, especially during warm-up. A manual switch wouldn't be a bad way to go, but you'd have to constantly keep an eye on your temp. Have you checked the switch?
  3. craveman85
    st. johnsville ny
    no i havent yet have to take some crap off the bike and find it.
  4. 02 VFR Rider
    02 VFR Rider New Member
    replace stock switch is best bet
  5. craveman85
    st. johnsville ny
    damn cheapest i can find is 84 bucks. ill just take my $25 switch that was going to go into my trans ams cooling system and use that instead it kicks on the fans at 190 degrees and should be fine for the bike with a thread adapter.
  6. red headed step child
    red headed step child New Member
    Clearfeild utah
    I just called Honda for my 85 and they said 48 bucks and about a week away. Still available.
  7. red headed step child
    Clearfeild utah
    Also check to make sure the ignition switch has 6 pins and not 5. The 83 switch has 5 cause they powered the fans differently that 84 and later.
