'84 VF500F Fuel Tank Mod: Advice Requested
Discussion in '1st & 2nd Generation 1983-1989' started by matthewjbradley, May 17, 2011.
  1. matthewjbradley
    matthewjbradley New Member
    Dayton, NV
    I have had difficulty with the fuel petcock valve on my '84 VF500F and after having no luck locating a new valve to replace it, I began entertaining alternative means by which to solve the problem.
    My main question (to all of you more experienced VF500F owners) is can I just remove the entire petcock valve assembly and go gravity fed on the fuel with an inline valve to shut off the fuel when the bike is parked?
    If so, is there anything else that you know on the subject that may be useful knowledge to me?
  2. invisible cities
    invisible cities New Member
    new york
    If the vacuum valve on the stock petcock has failed the petcock can be modified to bypass this. Removing the fuel pump is A-OK as gravity fed fuel delivery has been road tested and approved for the '84 and '85 models.
  3. elysse
    elysse New Member
    Lexington, Kentucky
