84' VF500F Carb Labeling
Discussion in 'Mechanics Garage' started by jacksonwalters, Jul 25, 2014.
Tags:
  1. jacksonwalters
    jacksonwalters New Member
    Boston, MA
    Just finished cleaning out the carbs from my '84 VF500F and just wanted to make sure I'm putting them together correctly. The '84's use two different types of jet needles, 2VF for the #1 & #4 carb and 2VD for the #2 & #3. Does the labeling start from the carb with the fuel valve being #1 and move right to left (as shown in pic)? Didn't see a diagram in the manual. Thanks!
  2. kennybobby
    kennybobby New Member
    #2 and 3 are the interior carbs, #1 and 4 are the 'outer' carbs on each end of the carb bank. Numbering is the same as the motor cylinders. The interior cylinders run hotter than the outer so the needles are different for the difference in temperature.
  3. jacksonwalters
    Boston, MA
    Ah, okay cool, looks like I made the right call. After putting the carbs back in it's idling much better, around 1300. However, at least one of the float bowls looks like it's leaking while it's on the kickstand. I imagine it's due to smooshed gaskets along with maybe a sticking float. I'll have to pull 'em out and take another look. Any of you guys know where to get '84 VF500 float bowl gaskets? Seems really hard to find specific ones online. Should I just make my own?
  4. kennybobby
    Make your own. There are standard sized o-rings (Parker numbers or something), but one of those sizes is supposedly a perfect fit--can be routed in the groove of the bowl cover. i've cleaned hundreds of carbs and never had one leak at the bowl gasket (knocks wood...), so i don't know the size number.
