84 700 carbs apart missing parts. Interchange?
Discussion in '1st & 2nd Generation 1983-1989' started by HAFRODD, Mar 26, 2016.
  1. HAFRODD
    HAFRODD New Member
    Claremore, OKLAHOMA
    I bought this 84 700 basket case. Previous owner was attempting to replace crossover tube O rings and left them for 10 plus years on his bench. One carb is removed from others and they are all removed from intake. I'm sure there are some parts probably missing. I have a motorcycle salvage close to me and found a bunch of carb sets with intakes still attached. They are not tagged so are there any identifying marks on them that would be for my bike? I did not take my carbs with me today when I was there. I think it would be best to buy a complete carb/intake set since I'm no professional V Four carb man. I'd like to send the carbs to someone to build if it's affordable
  2. TOE CUTTER
    At a quick glance you are missing quite a few parts, is there a bag or box that would have the screws, springs, and linkage in your collection?
  3. HAFRODD
    HAFRODD New Member
    Claremore, OKLAHOMA
    I found the crossover tubes with hoses still attached. Also 2 new in Honda packages, a short crossover T (plastic) and a bigger diameter metal tube with O rings. No other parts for carbs sadly
  4. HAFRODD
    HAFRODD New Member
    Claremore, OKLAHOMA
    Anyone got a complete 700 carb set? V45 Magna different?
  5. squirrelman
    PM'ed you. I can fix your carbs and (probably) source the missing parts. Most generously, TOE CUTTER supplied me with alot of miscellaneous small parts to fix a variety of VF/VFR carbs. :loyal:
