84 500vfr diaphragm needle help
Discussion in '1st & 2nd Generation 1983-1989' started by mackelby, Mar 7, 2009.
  1. mackelby
    mackelby New Member
    Missouri
    Got my carbs marked wrong, so inadvertently dont know what needle goes into what carb. 1&4 are supposed to be marked with 2VF and 2&3 are supposed to be marked 2VD. Mine are all marked 6BE. Could these be aftermarket? Really need some help here.
  2. volks6000
    volks6000 New Member
    Jacksonville , Florida
    could be aftermarket have to do a search on them use this web site then check google and you might want to give Jamie Daugherty a shout he's the 500 guy to ask.
  3. mackelby
    mackelby New Member
    Missouri
    Also found out fuel pump has been deleted. Not sure what to do with the large ports coming off carbs 2&4, if those ports are related to the fuel pump. which vacuum port on fuel selector goes to the intake off carb 2 and where does other one go to, is it a vent?? :confused: Now that its gravity fed does fuel ine from tank run directly to fuel tee between carbs??? Really need help!
    Mac
  4. volks6000
    hey you got pics of the carb and the lines that your talking about. is it a california model? because i have my carbs sitting right here next to me, just rebuilt them. can send you pics.
  5. mackelby
    mackelby New Member
    Missouri
    not sure how to determine if its calif model or not. Some pics would be nice. my address is mackelby@yahoo.com I would send you a photo but i don't have any pics at an url. Where do the hoses coming from carbs 2&4 go
    Mac
  6. masonv45
    masonv45 New Member
