'83 VF750f, Cant get tension on front cam chain?
Discussion in '1st & 2nd Generation 1983-1989' started by Hallmeister, Sep 12, 2012.
  1. Hallmeister
    Hallmeister New Member
    WA, Australia
    I'm new to this forum, just bought a VF750F a few months ago and trying to get it running, so far I've given the carbs a good clean and taken out the cams to check condition, trying to set timing and I can't get ehough tension on the front cam chain without the chain skipping on the sprocket, the chain and sprockets are in good cond not worn. There was good tension when i took them out but just can't get it back??
    Cheers
  2. TOE CUTTER
    It is common for the tensioner lock rod to get slight bend in it and then it will not want to slide and lock again, other things go wrong with then as well. I woul pull id back oot and inspect the rod and lock.
  3. Hallmeister
    WA, Australia
    Ok great, I'll check that out. Thanks mate.
