'83 VF750F Can not get front engine mount bolt hole to line up
Discussion in '1st & 2nd Generation 1983-1989' started by RoninWolf, Oct 14, 2015.
  1. RoninWolf
    RoninWolf New Member
    Bike has been sitting without the front bolt hole mounts aligned for months. Is it safe to remove the rear head dowel/bolt permanently to get the front ones in?
  2. GreyVF750F
    GreyVF750F Member
    West of Cleveland Ohio
    I wouldn't remove them. Just loosen all engine bolts and wiggle motor to get the fronts in. You may want to use a small hydraulic jack under the motor to get the weight off the bolts to wiggle easier.
