'83 rear tire question
Discussion in '1st & 2nd Generation 1983-1989' started by kelcam5, Jan 21, 2008.
  1. kelcam5
    kelcam5 New Member
    Northern Alberta Canada
    I'm looking at getting a Dunlop K205 for the rear of my '83.
    Will a 140/70-18 fit my first gen?
    How difficult is it to mount and balance yourself??
  2. pjvtec
    pjvtec New Member
    West Allis, WI
    I've changed alot of tires, but I would never ever try and change a tubeless tire by hand with tire irons. Take the wheel off yourself and take it to a shop. They will have a manual tire machine or a cool pneumatic one that will take off and put on in about 3 min. There's big chance you will mess up the bead of the tire if you don't know what you're doing. As for the balance, let them do it. Usually included in the price.If you don't know how to keep your axel square, use proper chain slack, watch out for the axel spacers, or trust yourself w/ a wrench, back away from the bike and let a pro do it.
  3. pjvtec
    pjvtec New Member
    West Allis, WI
    tire size? 130/90-16 for a VF750C, 130/80-18VF750F, 130/90-17 VF750S
  4. James Popp
    James Popp New Member
    Wisconsin
    I don't know if you can put the 140/70-18 on the bike. I'm running a 140/80-18 on the rear right now (Bridgestone Battlax45). The manufacturer approves my taller tire for the rim but not the 70's. The Bridgestones are good tires, I'm going to put a 16-tooth front sprocket on this year though to compensate for the extra-tall tire.
  5. kelcam5
    kelcam5 New Member
    I didn't consider the rim/profile effect. So 80 series profile is the thinnest I can run?
    BTW, I've run Battleaxes before and didn't care for them.
  6. James Popp
    Wisconsin
  7. VT Viffer
    VT Viffer New Member
    South Carolina
    Do motorcycle tire sizes follow the same sizing vein as automotive tires?
    In other words, the first # is width, the second # is aspect ratio, and the third is rim size?
    If that is the case, the below is also true:
    130/90 16 = 640.4 mm Overall static diameter
    130/80 18 = 665.2 mm OSD
    130/90 17 = 665.8 mm OSD
    140/70 18 = 555.2 mm OSD
    140/80 18 = 681.2 mm OSD
  8. James Popp
    Wisconsin
    Yeah, you're on the right track. But the 140/70 18 should be 653.2 mm
  9. bear
    bear New Member
    Ajax, ON
    A 140/80 is the same width as a 140/70. The aspect ratio (the 70 or 80 part) is the percentage of height to width. The first part is the width of the tire. If you can fit a 140/80, then a 140/70 will also fit width wise. If will be a shorter tire though. Typically you would go to a 150/70 from a 140/80 to retain the height.
  10. James Popp
    Wisconsin
    Almost everything you say is true. However, the rims of these bikes are very narrow. Therefore, they need the extra sidewall height to step up to the wider 140 mm width. Bridgestone doesn't suggest using the 140/70 profile with a 3.00 inch wide rim, but they allow the 140/80 profile.
  11. fabinator
    fabinator New Member
    Seattle, WA
    I have a 140/70 on mine, and it will indeed work. The problem with that size is getting the damn bead to seat... no matter how much soap I used, it just wouldn't get the last little bit. I had to wait until morning, let it sit in the sun for hours, soap it up again, and only then would the bead seat... with 120psi.
    using pressure that high was risky, and I wouldn't recomment trying it. The bead seems solid on the rim, but it may be prone to dismounting. I'm only using the tire temporarily.
  12. Sebspeed
    Sebspeed New Member
    Catskill Mtns, NY
    I recommend a 120/70-17 front and a 160/70-17 rear.:biggrin:
  13. kelcam5
    kelcam5 New Member
    Well to update everything. I was able to get a few Shinko radial "Canyon R002" 130-80/18 for a decent price. So if anyone out there needs one, let me know.
  14. keny
    keny New Member
    Finland
    city of Karjaa, Finland North Europe
    I have a 140/70-18 Bridgs BT45 on my VFR. Ok it has a 3,50 rim but I got that tire from one that buoght a old FZ750 Yam that had fresh BT45 mounted (140/70 rear and stock 120/80 front). It has a 3.00 rim. I can say that the tire profile was werry of on that 3.00 rim, and it had 8-9mm chicken stripes, even non on the front! Bridgs recomend the 140/70 for a 4.00 rim and I can see why. On my 3.50 rim it leave still some 3-4mm chicken stripes when it left none whit a 130/80. Still Bridgs suggest a 3.50 rim is OK.
  15. Alaskan
    Alaskan Member
    Alaska
    Just use the tire sizes recommended for the stock wheels. If you want more choices, upgrade your wheels.
  16. masonv45
    masonv45 New Member
    I have an Avon Azaro 160/60 on mine that the PO put on. Looks good and hasn't lost a bead yet. Since it was brand new, I'm going to run with it. But when it comes time to replace it, I'm going to go with 150 or 140.
  17. Sebspeed
    Sebspeed New Member
    Catskill Mtns, NY
    You've got a 160 on a stock wheel?!?!?!?
  18. keny
    keny New Member
    Finland
    I would NEVER but a 160 on a stock VF rim, Seen them on 3,5 rims, and its not good looking, and you use only 60% of the tread whith, a 3,00 rim even worse! You have a big risk something bad happens!
  19. masonv45
    masonv45 New Member
    Here's a pic of the bike with the tire.
    Personally, I would not go larger than a 150, but the 160 is what the PO installed.
    When riding, in a straight line, I only use about 1/3rd of the tire tread. Which, when compared to a stock tire, is about the same footprint. So really, there is no benefit for a larger tire on such a small rim.
    The tire is a radial so the sidewalls 'should' be strong enough to handle the side loads.
