6th Gen Valve Check tips/tricks
Discussion in 'Mechanics Garage' started by jch82, Aug 13, 2014.
  1. jch82
    jch82 New Member
    Cincinnati, OH
    My 2006 has just touched the 60k mile mark and I have planned a bit of maintenance. I have put the last 30k on the bike and never checked the valves. It is unlikely they were checked before that as well. Any tips/tricks you guys have to get the job done? I've always done my own wrenching and have the Honda service manual as well.
    Also, anything else you guys recommend I check/replace while I have basically the entire engine apart?
    Josh
  2. TOE CUTTER
    Just bring your patience with you and you will be fine, it is a bit of a pain but if you know that going in your less likely to get pissed off and start screaming "what the fuck!". It is best to just disassemble/remove aboot anything that is in your way as well.
