6th Gen Valve Adjustment Question
Discussion in 'Mechanics Garage' started by Meatloaf, May 12, 2016.
  1. Meatloaf
    Meatloaf New Member
    Indianapolis, IN
    I'm in the process of adjusting my valve and am putting things back together. I've reinstalled the front camshafts and their holders and torqued to specs. I can't find anything that talks about Cam Chain Guide B which is the one that sits above the camshafts. I can't find any reference to it in Chapter 8 of the service manual at the beginning or through the chapter. Anyone have any idea what the torque spec is to this and if I need to use thread locker or not
  2. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
    At the front of your Service Guide ... there's a general torque spec for the different sized bolts (M6, M8, etc.)
  3. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
    Honda Service Guide ... Page 1-12 is where all the Torque Value specifications starts.
    Page 1-13 under CYLINDER HEAD & VALVES
    Came Chain Guide Flange Bolt - Qty 2 - Thread Dia. 6mm - Torque 12N.m or 1.2kgf.m or 9lbf.ft - NOTE 2 - Apply a locking agent to the threads
  4. Meatloaf
    Meatloaf New Member
    Indianapolis, IN
    I thought the flange bolts were the ones that attached Cam Chain Guide A. Apparently they both are flange bolts. Guess I'll have to take them back out and put some loctite on them tomorrow. Thanks for the help.
  5. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
    No problem! :)
