6th Gen Rear Fender Options
Discussion in '6th Generation 2002-2013' started by stewartj239, Mar 22, 2007.
  1. stewartj239
    stewartj239 Member
    Syracuse, NY
    Can anybody recommend a rear fender option for the 6th Gen that eliminates the lower hanging part where the reflector resides? I'm not looking for a fender eliminator kit. I want the fender, but I would like it shortened and I am not brave enough to shave it myself as I want it to look professional as opposed to a hack.
  2. reg71
    Sikeston, MO
    If you mark it while it's mounted by using the bodywork as a guide then remove the rear portion of the fender, you can using a fine tooth saw or take it to someone to do it. You should be able to make it look just fine with a clean cut and minimal sanding.
  3. stewartj239
    stewartj239 Member
    Syracuse, NY
    For plastic, will a lightweight sand paper be OK? If so, can you recommend the proper grade?
  4. DANIMAL
    DANIMAL New Member
    Metairie, LA USA
    :car:
    the fender is actually two pieces. get rid of fender A part. I got a competition Werkes fender eliminator I really like. check it out in my gallery. get rdi of that trolling motor. 59 bucks.
    hey Reg, I got a PCIII on order from Cyclemart in Dallas special VFR Forum price 245 free shipping i US. I love this forum. I am offshore and I also got a new ZG doubble bubble. when I get back on april 4th I am gonna do some mods and miles. I can't wait to get home.
  5. stewartj239
    stewartj239 Member
    Syracuse, NY
    I checked it out and I am surprised that the fender eliminator kits for the VFR actually look much better than I thought. I decided to just order the Competition Werkes kit and I'll just put my stock fender in storage. Thanks for the tip.
  6. cooper_mm
    cooper_mm New Member
    Cincinnati
    I just put one on my '03 and it looks good. Tip to anyone planning this mod: Loosen the seat cowl and find someone with slender fingers to help!
  7. jasonsmith
    jasonsmith Member
    Vancouver, BC
    My buddy actually cut his up on his Repsol... As long as you use a fine blade as noted above and clean it up somewhat only a trained eye will notice that anything was done. I think the material is even thick enough to cut on a slight angle to impart a factory style look. By far the cheapest and simplest solution.
  8. KrautBurner
    KrautBurner New Member
    Bremerton, Wa
    just do it,
    mark it while on the bike,
    trim it with above (or use a dremel)
    then clean it up with sand paper (heavy grit to shape. then work to finer)
    start with 80-120 grit, finish with 220ish
    good luck
  9. stewartj239
    stewartj239 Member
    Syracuse, NY
