6th gen forks, fork oil.
Discussion in 'Mechanics Garage' started by DanBjR, Apr 19, 2020.
  1. DanBjR
    DanBjR New Member
    Did a full seal, bushing, and oil change on the bike today.
    I'm curious as to the effects of oil level on dampening/suspension characteristics. Unfortunately I only had 1 liter of oil so instead of the 544ml (18.4oz) I only put 500ml in each until tomorrow.
    I seem to have read the air gap was 100mm but 90-110mm allowed. What will this do overall? And as I'm curious. Why?
  2. Terry Smith
    The fork's resistance to bottoming is provided by a combination of the spring, plus the compressibility of the air above the oil. The air makes most difference when the fork is near to bottoming, and increases the bottoming resistance. So less oil won't be too noticeable until you brake hard or hit a decent bump, then you are more likely to bottom out. The recommended oil level (springs out, fully bottomed) is indeed 100mm.
  3. raYzerman
    raYzerman Member
    Millgrove, ON
    If you have aftermarket springs (usually slightly gauge spring wire), typical oil levels are lower, more like 130mm. Your wee bit low is nothing much to worry about, just more air cushion. What you don't want is too high an oil level, if it bottoms out so to speak, you push oil past the seals.
  4. DanBjR
    DanBjR New Member
    Well that makes sense. I was worried I'd have issues. I'm still going to add the missing oil.
  5. Diving Pete
    you absolutely want the air gap to be correct. You will be able to ride the bike but dont hammer it.
  6. Brianinoz
    Brianinoz New Member
    Hi Dan. have a look at Dave Moss tuning, he is the suspension Guru. Cheers Brian.
