5th Gen Windscreen Screw/Expander Nuts issue
Discussion in '5th Generation 1998-2001' started by bikehikeflyCO, Apr 19, 2015.
  1. bikehikeflyCO
    bikehikeflyCO New Member
    Fort Collins, CO
    So, I had to take off my windscreen to get to the dash to change a burnt out bulb. When I went to put the screen back on, both screws that I removed just kept turning and turning, so I had a look. They are expander nuts (or whatever you call them) that go in to the holes on the side of the fairing and they have stripped out the hole that holds them. The holes are now too big to even hold them in and they rattle around just waiting to fall out. Any suggestions on what to do? Thanks!
  2. zoom-zoom
    zoom-zoom Member
    BC, Canada
    I suffered the same issue with my bike a couple years back and I lined up the inserts where they were supposed to sit and then I put the screws in the inserts and used some JB Weld to epoxy them back in place. Once the JB weld had hardened I backed the screws out re-installed the fairing and put it all back together. Worked like a charm.
  3. nookiaz
    nookiaz New Member
    Montreal
    Zoom Zoom mentioned some plastic repair material to me some time ago as I have the same problem. I never got around to order the stuff (call me the procrastinator) but I believe this is it:
    http://www.plastex.net/Home_Page.php
    Hope this helps.
  4. OOTV
    OOTV Member
    I basically did what ZoomZoom did but with a plastic repair kit. It wasn't plastex, but very similar, don't recall the name off hand but principle is the same. BTW, I coated the screw with WD-40 before I screwed it into the connector, just to make sure the screw didn't bond with the repair material.
  5. bikehikeflyCO
    Fort Collins, CO
    Thanks guys, will give that a try!
  6. rjgti
    rjgti New Member
    regina sk
  7. rjgti
    rjgti New Member
    regina sk
    and you get 25 of them for 15.00
