5th Gen Wheels
Discussion in '6th Generation 2002-2013' started by AWP34, Oct 18, 2014.
  1. AWP34
    AWP34 New Member
    Hello VFR's
    I wanted to know if there is anything special I need to do if I decide to go with the 5th gen wheels on my 08 VFR? Is the bolt pattern the same? Any info on this mod would be greatly appreciated.
  2. OOTV
    OOTV Member
    Bolt pattern is the same since the 3rd Gen. The issue is that you can't go from later gen to earlier gen due to the rear hub wheel studs. Hence the use of the 3rd Gen 8 spoke with 5/6 Gen bikes.
  3. V4toTour
    V4toTour New Member
    Yeah you can, just have to make cutouts in the later rim.
    Fast forward to 3:00
    [video=youtube;qOfMG22EvxM]https://www.youtube.com/watch?v=qOfMG22EvxM[/video]
  4. OOTV
    OOTV Member
    Probably should have been more specific, it is not a direct bolt on.
