5th Gen wheels compared to 6th Gen
Discussion in 'Mechanics Garage' started by mr_pantera, Sep 15, 2006.
  1. mr_pantera
    mr_pantera New Member
    Does anyone know if 5th Gen wheels will fit on a 6th Gen? What is the difference?
    Honda shop said part numbers were different but did not know if 2001 wheel would work on 2004 model. Did a search but did not see anything.
    Thanks,
    Jeff
  2. SA1713
    SA1713 New Member
    The 5th gen wheels (front and rear) are exactly the same as the 6th gen. Both interchange. Front rotors are the same as well.
  3. mr_pantera
    Thank you SA1713.:biggrin:
  4. Echolynch
    Echolynch New Member
    What about a 4th Gen on a 5th Gen? Specifically, 1996 on a 1998? Reading the sizes, it seem the 5th Gen is Wider but the same diameter?
  5. SAFE-T
    SAFE-T New Member
    All VFR rear wheels from '90-present are 17". The 4th gen. wheel weighs 12 lbs, which is actually lighter than some aftermarket wheels...
