5th gen throttle control elements
Discussion in '5th Generation 1998-2001' started by BlueRider, Sep 2, 2013.
  1. BlueRider
    BlueRider New Member
    Is the 5th Gen throttle all mecanic or are there electronics involved? I'm asking because I had an incident where the motor suddenly revved uncontrollable when taking off, and I need advice on what the shop has to check to find a possible cause for this behavior.
  2. CRFan1
    CRFan1 New Member
    Northwest Indiana
    It is purely mechanical in that cables are used to turn the throttle shafts, which in turn controls a TPS sensor. Not 100% sure how that could happen unless the cable got stuck......curious to hear the outcome.
  3. BlueRider
    Someone on my Norwegian mc forum suggests failure in the TPS sensor. I don't think it was a stuck cable since I was hardly applying any throttle when it happened.
  4. CRFan1
    CRFan1 New Member
    Northwest Indiana
    Yeah...the TPS is really the only thing that may cause that if it had an erroneous voltage spike from a bad potentiometer. There will be a test to check that it has a smooth transition from say 0-5 volts (check the manual for voltages) as you move the throttle, with no jumpyness or voltage spikes, etc.
  5. rocketscientist
    rocketscientist New Member
    australia
    sounds like a loose wiring plug or intermittent short somewhere.
