5th Gen Starter switch replacement. Any guides?
Discussion in 'Mechanics Garage' started by spridget, Jun 18, 2012.
  1. spridget
    spridget New Member
    Deep in the Heart of Texas
    I'm looking for a how-to to replace the starter switch on my '99. It began having trouble with the headlights. I disassembled and cleaned the contacts. That helped for about 6 months. Now it's apparent that the switch is bad (broken internally). I have a factory service manual, but I didn't find how to remove and replace the entire switch and cable assembly (admittedly, I didn't look very hard). I've also used the search function here, and didn't come up with anything.
    Any advice on how-to and where I should locate parts is most appreciated. I can't (won't) ride the bike without a headlight and it's killing to see the bike just sitting there due to a such a minor problem.
    Thanks!
  2. VIFFER RIDER
    VIFFER RIDER New Member
    Socal
    I just replaced mine a week ago, it was a PITA! The part that fucken frustrated me was the gray plastic bezel removal, how the fuck does it come off without having to distort the hell out of it? I took off the clip ons bars to get that bitch off, then removed a couple of 10mm nuts so i can move the cluster forward enough to get to that damn pesky red connectors behind the cluster. The new switch was cheap though about $48 but damn the job looked easier then i thought.
  3. spridget
    spridget New Member
    Thanks. Ya, I've wanted to have the dealer fix it but the nearest one is an hour away. Last time I checked on the part it was $90. Did you buy the part online or in a store?
