5th gen Sprockets?
Discussion in 'Mechanics Garage' started by Edwii, Mar 22, 2016.
  1. Edwii
    Edwii New Member
    Chilliwack
    Did some research, Pretty sure I want to go with 530 17t and 45t, but not sure where and which to order?
    I'd like to get everything from canadasmotorcycle.ca which offer JT sprockets, but I don't know which 45T will fit?.. or If I should order something different.
    Please advise, thank you.
  2. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    I got my DID chain off Ebay, and my sprockets from http://sprocketcenter.com/ . Some guys prefer the OEM countershaft sprocket because they say they're quieter with the rubber around them. I can't tell any difference, but to each his own.
    The 17/45 combination is a winner.
  3. lanesmatb
    lanesmatb New Member
    Maryville, Tennessee
    I just replaced my chain/sprocket with a 17/45 Superlite kit on my 5th gen from Sprocketcenter. EK o-ring chain (gold) and steel superlite sprockets are definitely lighter and look nice to boot. They are also on sale for $187.00 which is a good deal for the kit. The superlite sprockets is a nice upgrade for the price.
    Cycle Gear has been running the chain press on sale for $40. You'll need one of those if you plan on bradding the masterlink yourself.
    Good luck.
  4. JimHanus
    JimHanus New Member
    If you don't buy it in a kit, be sure all the parts are 530. I bought separate pieces once that were supposed to all be 530, but the front sprocket turned out to be a 520. Didn't even notice, and ran it quite a while until I looked close and there seemed to be quite a bit of space between the teeth and chain.
  5. V4toTour
    V4toTour New Member
  6. lanesmatb
    A pic of the Superlite. The sprocket just below the teeth is undercut (thinner) so it actually is quite a bit lighter than the stock.
