5th Gen Seat stuck and wont come off, please help
Discussion in 'Anything Goes' started by dino71, Jul 23, 2009.
  1. dino71
    dino71 New Member
    New Jersey
    Well the short story is that I think when I placed my seat on my 1998 5th gen VFR after I did some maintenance I did not slip that thing in front of the seat under the "U" bar and I then forced it into the lock in the rear. Now I cant remove the seat and when I attempt to push the lock release lever down it hardly moves. Has anyone gone through this before? Any ideas on how to remove the seat with out breaking the locking mechanism?
  2. Ghost_Rider
    Ghost_Rider Active Member
    LA & Utah
    Did you try pushing down on the rear of the seat while you are depressing the seat release lever? At the same time I mean? Try pushing down on the seat and/or wiggling it as you push the release lever down.
  3. dino71
    dino71 New Member
    New Jersey
    Tried that but only by myself. I may have to enlist the help of my neighbor and then try a crow-bar :frown:
  4. Ghost_Rider
    LA & Utah
    Do not use a crowbar. If you need to, take off the rear cowl, and that might give you some extra play/access to the lock. You should be able to take the rear cowl off without having to remove the seat. It will be trickier, but with a little ingenuity you can do it.
  5. dino71
    dino71 New Member
    New Jersey
    The cowl isnt on the bike (its never been on the bike). I just need to be able to take the seat off because sometimes I use the little bit of space under it as storage.
  6. Y2Kviffer
    Y2Kviffer Insider
    RALEIGH, NC
    Had that happen once. If memory serves, had to push down on the seat while pushing down the latch. Then lifting up on the back of the seat (latch still being held down) and pushing back down several times. Cussing like a sailor definetly helped the process :wink:
  7. Pliskin
    Pliskin New Member
    Morris County, New Jersey
    Hey Dino - Would it help if you loosened the bolts that secure the front of the tank, to possibly give you some play in the seat? Just a stretch... Good luck bro.
  8. dino71
    dino71 New Member
    New Jersey
    That's not a bad idea :thumbsup: I am going to try that tonight if its not raining.
