5th Gen pictures of wire routing
Discussion in '5th Generation 1998-2001' started by Mogman, Dec 25, 2012.
  1. Mogman
    Mogman New Member
    Mojave Desert
    Hi guys- This is my second 5th gen VFR. My first one (2001) was pristine and I never had the upper cowl off. My current Beast came with all the plastic in a box, and the wiring hanging off of the upper stay... Does anyone have any pictures of where each wiring loom / relay is suppose to go? The factory manual leaves much to be desired with just line drawings. Also, if someone has pictures of how the inner fairing pieces attach, that would be great! Thanks in advance!
  2. derdummkopf67
    derdummkopf67 New Member
    Los Angeles
    Hopefully this helps a little. Sorry if they're a little blurry.
  3. Mogman
    Mogman New Member
    Mojave Desert
    Yes, that does help. It looks like all the wires are behind the stay except for the main loom that comes from the left side of the bike. Probably the most important is to keep the wires from behind the headlight so that it can seat into the 2 rubber grommets. Thanks for the help!
