4th Gen Sub air filter
Discussion in '3rd & 4th Generation 1990-1997' started by Sye, Jun 9, 2008.
  1. Sye
    Sye New Member
    Wirral UK
    I am writing this in response to the question on this thread
    http://vfrworld.com/forums/vf-vfr-mailing-list/15755-97-advice-offered-advice-needed.html
    I am unable to post on that thread and I can shed some light on the problem.
    The sub air filter is not connected to the air box in any way. It is connected to a breather pipe that connects all four carb tops. The purpose of this breather is to allow the flow of air both in and out when the carb diaphragm expands and contracts. If the filter is blocked then the carb slides will work but the diaphragm will be in a vacuum and won't move.
    It is located on the right hand side between the frame rail and air box. It should be cleaned whenever the air filter is replaced. You have to unclip the base and remove the foam element, clean it in solvent, re-oil it and replace. Beware of over oiling it as this stops the airflow and can also cause problems.
    Hope this helps?
  2. VT Viffer
    VT Viffer New Member
    South Carolina
    I have wondered about that thing as well.
    When I had my bike apart this past winter, I figured I'd remove it and clean it as per the service manual.
    When I got it off and apart, the "filter" foam was disintegrating, and fell apart completely when I attempted to clean it as instructed.
    As a replacement, I used a 2"x 3" piece of polar fleece (made from recycled plastic bottles, BTW) in it's place.
    Houston, do we have a problem???
  3. Sye
    Sye New Member
    Wirral UK
    No, I don't think you will have a problem. So long as it keeps out the airborn rubbish it will be OK. I would replace it at the next service though, it only takes a few minutes and costs arount £1.50 ($3.00) to buy so it's not expensive.
