4th gen hard luggage
Discussion in 'Gear & Accessories' started by R. Guy, Jul 1, 2009.
  1. R. Guy
    R. Guy New Member
    Chucktown, SC (Charleston)
    Does anyone know of some good 4th gen side luggage (hard) that will fit a fullface?
    Are there OEM hard bags out there?
  2. safetypro10
    safetypro10 New Member
    Dallas, TX
    4th gen luggage
    twistedthrottle.com
    Larry
    VFRrider
  3. carbon
    carbon New Member
    I just recently picked up a 96 VFR and I've been thoroughly examining my luggage options. Here's what I've found so far, and maybe somebody can clarify where I'm wrong.
    We have a couple of options as far as luggage racks go.
    Givi Wingrack - Quality but pricey, also makes the back of your bike look like something out of robocop. There are a couple different 4th-gen specific versions of the Wingrack; one kit only comes with the top case mount (F242). I've seen that range from $110 to $160 for the exact same part. I have not been able to find a picture of the included components, so I have no idea what F242 actually looks like. The other kit comes with two part numbers, contains the giant, ugly side brackets, and costs around $280. Givi cases receive great reviews from serious riders, but I have seen the $40 givi knockoffs receive just as much praise. I am looking into buying just the trunk rack, which I think comes in a less-intrusive tube frame design. I am also trying to find weight limits on the F242 or the other rack setup. Any info here would be appreciated.
    Ventura Rack - Ventura makes a nice looking model-specific tail rack. ~$250 will get you a sport rack and a regular, larger rack, with a decent (softcase)rack pack included. The Ventura system is similar to what I picture the Givi F242 to be like; It's a skinny tube frame design that mounts to two open bolt holes on either side of your subframe. However I know the Ventura's weight limitations to be in the neighborhood of 20lbs. To me, having a 40 liter trunk that can only hold 20lbs seems like a waste! Then again, after you look at the parts list for either a Givi F242 or a Ventura setup, they both use skimpy 8mm bolts to secure the rack brackets to the subframe. They also note that the ventura rack is not to be used with any type of hardcase or backrest application, but I have read euro forums where it is commonly practiced.
    The full Givi Wingrack secures to 6 points instead of 4. It's robocop-esque design may be the only option we have for sturdy weight carrying trunks and bags. I did find this, which appears to be an old page describing a brand called Five Star.
    Five Stars Rack 1
    This is the kind of rack I want. It's discreet and tubular design mounts up to a total of 8 points from what I can see. There is also a top rack component, which is not displayed on the above link. The company is now Hepco & Becker, and the only price I was able to find made the Givi Wingrack look affordable!
    Anyway, the problem is not the luggage. There are many options for trunks or hard bags, ranging from economic to luxury, and they all come with a lock and key which is my only reason for wanting hard luggage in the first place (that and a backrest for the lady for less than a corbin gunfighter with backpad ($700 item, and pretty much the only option i've seen for a non-trunk passenger back rest on the 4th gen VFR750s)). I don't want to fully commit to having luggage on my bike at all times, so I've figured I could make do with a tough looking trunk with backrest, and maybe some nice large soft luggage(Rapid Transit Recon 77 Saddlebags would give me 70 liters of cargo capacity with easily a 100lb load). The bike would look soo ugly with a naked Wingrack on it when I want to just go out and ride. With soft luggage, it's a flip of a strap and I'm back to normal.
    I could see myself getting one of these
    Emgo Portable Travel Trunk - Street Bike - Accessories - Motorcycle Superstore
    Finding a trunk is not hard. Finding a rack that is going to fit our bike is the tricky part. I was considering looking into a custom option, but by the time you've designed it, welded it, powdercoated it, you might as well just throw in for something commercial.
    Stay away from the Rentec racks. They look great, are priced at around $150 after euro conversions and outrageous euro-to-us shipping rates, but they are only rated at a maximum of 5lbs. The top case that you'd mount would weight more than that! There were a lot of reports of euro riders having issues with these racks, as the Rentec connects only to the two passenger grab bar bolt holes. Some of these guys were also drastically over-loading the rack (30lbs+), but if you follow the guidelines it's almost useless except for light commuting with a passenger.
    Luggage racks are a very handy thing, but I don't want to spend $300 to tote around 20lbs in a case and rack system that can barely sustain it's own wind resistance, let alone my intended abuses. Motorcycle luggage can place a lot of strain on brackets and subframe mounts if it's not done properly or if it gets used beyond spec. I'd really like to be able to carry a decent load (40-50lbs) in a hard case trunk without a giant modification to my bike and without 30lbs of folded sheet metal indiscreetly located wherever Givi found it appropriate.
    I mean, seriously, I'm 6'3, 220lbs. 2 days worth of my clothing easily exceeds 20lbs. It's not like i'm wearing nice shit either. Old navy jeans aren't exactly heavy weight tacticool gear.
    Thanks!
  4. RedMenace
    RedMenace New Member
    DRC, the Congo
    I looked and researched, too. '96
    I found a used Givi- non WingRack- made in the '90's before the WingRack became their cross platform design. I'll add this, my bags are Givi 38's and they don't fit a full size helmet! Thought it was a euro standard. It is very close, so maybe another brand of helmet will fit. My Bell and my KBC do not fit.
    Also, my rack design does not incorporate the grabrails. It has 3 mounting points, and a cross piece. I pack some essentials in them, but never stuff them full. I use a larger tail bag when touring. I believe a nice hard-case looks fine on a VFR, but had to solve the problem from another angle. Soft top case, easily removable, stuffed with heavy camping crap- hard luggage, stays on cycle most of the time, stuffed with light crap.
    I had an overloaded top case snap off an old Goldwing after a hard RR crossing many years ago.
  5. Spike
    Spike New Member
    Givi is really the only way to go. If you want quality, lockable, hard luggage. Are they pricey, yes, but with the bags you can own them for years and years and take them from bike to bike. The brackets, at least I have never seen require any modification to your bike like any cutting or anything like that. Just bolt on. So when you sell the bike, you take the bags with you to the next bike. Take the rack off the old bike, sell it on EBay and get 50-70% of the original price back, and it really wasn't so expensive after all. Also the brackets are made for your make and model bike, they don't send you some sort of universal kit and then you are left trying to make it fit your bike. So you get what you pay for. I have actually lifted a bike up by its Givi rack, they are that solidly mounted.
  6. SLOVFR
    SLOVFR Member
    Lompoc Ca.
    Givi is the only sensible option for hard luggage. I maybe able to help in a new wing rack for you. You need the Y154 mount kit and some bags you can score on Ebay. An E360 bag will hold a full face but I find the E460 fits better and holds 2 real nice I use for the back.
  7. carbon
    carbon New Member
    That looks great! I want a givi windscreen badly! Is that a sargent seat?
    I think the Givi F242 rack would be simple enough for my needs. I'm looking into them next week.
  8. eleman
    eleman New Member
    Hudson, IL
    I have a Givi wingrack 2 and the E360 cases for sale. See my ad in the classifieds. Looks like SLOVFRs except I don't have the top case. Those are the same side cases though. Asking $400 shipped in the U.S.
  9. SLOVFR
    SLOVFR Member
    Lompoc Ca.
    Thanks, its a Corbin seat. Time to have it recovered though, getting a bit worn but I like it better than the stock due to I dont slide into the tank with it.
  10. GeorgeGTS
    GeorgeGTS New Member
    So I just bought a 1996 VFR and I wanted to get luggage for it, but it appears that Givi has stopped making the mount for the wing rack for the VFR. I already had two Givi cases that I wanted to reuse, but I need to figure out how to mount a wing rack or something similar. Anyone have any ideas on where I might still be able to get the Y154 mount kit?
  11. mikelaubach
    mikelaubach New Member
    I was surprised to read that Givi stopped making the rack for VFR's so I had to go look myself. One of the first that came back from Google was
    Honda VFR Interceptor seats, luggage, bars, exhaust, and accessories
    But there are other places as well, such as:
    GIVI Y154 Wingrack Fitting Kit - Honda VFR 750F ('94-'97)
    I agree with the others who have said Givi is the way to go. I have the Wingrack II on my '94 and utterly love it! I have the E21 and E41N bags. The E41's are huge and look like UFO's trying to land sideways on the bike, AND they make me arse look big, but eh, they hold a ton of stuff. I took a two week, 3000 mile trip a few years ago to attend training for work, and they fit my clothes (no re-using in training sessions, gotta look good), my laptop, and other required bits. I had my tankbag for "immediate need" items like raingear, etc. The E41's are too large for a simple weekend away to a friend's house, so I recently got the E21's. I am not as impressed with them, but they do look better, offer less wind resistance, and I don't get things knocking around due to using a bag that is just too large for what I need. the mounts are rock solid - handgrip location, passenger peg location, and a tie bar between the two. I bought the full kit with top-plate, though I have never used it. The top plate would add yet another point of connection between the two. I have noticed no stability issues even without the top plate.
    That said, even the Wingrack II is conspicuous. I don't love the look with the bags off, and you can't use the single seat cowl with the mounts. But overall, I can deal with the plates given their massive benefit when loaded with gear.
    --MIKE--
  12. GeorgeGTS
    Wingrack
    Okay, so even though GIVI is no longer making the fitment kit for the older VFR (4th gen and previous) I found out that Twisted Throttle still had some so I have it on order. I'm very excited about getting the cases mounted.
    Does anyone know off-hand if the cases will fit if the bike has an after-market exhaust that it mounted about 4 inches higher than the stock?
  13. mikelaubach
    George, you might be in trouble there. I am looking at my bike right now, and the can sits just below the side plate.
    I can get a pic if you want.
  14. GeorgeGTS
    Thanks, I'd really appreciate it if you could send me a picture. If you want to email it, georgegts@gmail.com
  15. mikelaubach
    Ignore the old outdrive parts in the background. hahaha
  16. Jarvis
    Jarvis New Member
    Fayetteville, GA USA
    I picked up a Wingrack from a 1997 VFR that was totaled. The issue I ran into is that it is the original Wingrack and unfortunately there are some brackets that he left on the bike when the insurance company picked it up.
    The mounting kits I see at Twisted Throttle are for the Wingrack 2 and they do not appear to fit the original Wingrack. Any ideas?
  17. SLOVFR
    SLOVFR Member
    Lompoc Ca.
    What brackets are you missing. Im pretty sure the brackets will fit both the wingrack and the wingrack II.
  18. Jarvis
    Jarvis New Member
    On my Wingrack, there is a bar that runs just under the side panels with two holes in it where the original owner said he would bolt it to his bike. From the installation PDF I saw this bracket does not exist on the Wingrack 2. I have seen pictures of the original Wingrack on a VRF and there are no attachments up by the passenger grab rails which is shown on the PDF. Never realized there were two different versions of the Wingrack when I bought the thing. Oh well an informed customer is a wise man.
    I contacted the original owner and he is contacting his insurance carrier to see if they can locate the bike.
    Based on what I have seen so far there appear to be at least one boss on the rear subframe where I could fab and a attach a bracket. Just not sure of the other point.
  19. SLOVFR
    SLOVFR Member
    Lompoc Ca.
    Is the kit you have for a 2 bag or 3 bag set up I wonder
  20. Jarvis
    Jarvis New Member
    It is the three bag set up. Two side bags and one top box. I was looking at the Wingrack 2 Installation Guide for the VFR and I think you may be right. The mounting kit for the Wingrack 2 may fit the original Wingrack. Although it appears I loose the passenger grab handle with the rack in place but I don't think that is a big issue.
    I sent Givi an email about this and I will see what they say.
