I was trying to fix a broken mounting tab on the back of my gauge cluster the other day and accidentally cut through (3) of the circuit ribbon lines on the lower right of the gauge cluster. Near the square box on the back of the cluster. My question is, is there any way to solder those gold lines back together? I haven't tried the gauges but I'm sure the are not going to work. If you have any suggestions please let me know. Thanks, Kent
Your best bet would be to lightly scrape the protective coating off of the areas you want to solder and the use small jumper wires to connect if you cant find another cluster.
