4th Gen Aftermarket Petcock Installed.
Discussion in 'Mechanics Garage' started by VictorRomeoFrank, Nov 8, 2024.
  1. VictorRomeoFrank
    VictorRomeoFrank New Member
    I finally got around to installing the new petcock, here's a few photos so you can see the fit and finish, which is superb.
    ridervfr likes this.
    Hell yeah. Nice.
  3. mello dude
    Pingel?
  4. VictorRomeoFrank
    It is indeed a Pingel. Pricey but well worth it. My original had sat for many years and a hole corroded through it and the orings were toast. I found one used on on ebay that, while functioning, also leaked. So...I made a handful of mounting plates with 3/8 npt holes so I could install a quality rebuildable unit like the Pingel pictured above. Done and Done.
    I bought just a mounting plate to future proof myself. It is sweet.
    VictorRomeoFrank likes this.
  6. VictorRomeoFrank
    Indeed you did....mine is also a thing of beauty.
  7. VictorRomeoFrank
    And here is the steering damper mocked up. It's a tight fit but it does the job.
    Did you put a zip-tie on your left fork to see how far your fork lower normally travels up the tube?
    This is mine with .95 RaceTech springs, proper oil height and pre-load. You can see the marks for how far it was going during normal riding and then that being the extreme, likely a bump during hard braking.
    You can also see how far it went before adjusting the oil height and preload to get proper sag numbers after the initial set-up and break in.
    Bike is on center stand for this pic and the forks are thus extended.
  9. VictorRomeoFrank
    Yes, and you raise a good point...for each rider the install will be a bit different and you should adjust accordingly.
    Good lookin out
