4500 Miles Metzler Road Tec Z6...
Discussion in '5th Generation 1998-2001' started by HellFishTat, May 31, 2015.
  1. HellFishTat
    HellFishTat New Member
    Raleigh, NC
    and it's toast
    I live in Central NC, so I don't get a lot of twistie fun (as evident from the size of the chicken strip)
  2. OOTV
    OOTV Member
    :hss: What tire pressure are you running and do you have a heavy throttle hand?!
  3. HellFishTat
    Raleigh, NC
    I check it weekly (I know I should do it more often) and it's usually leaked down to 39psi. I fill it back to 42psi. 36psi front and 42psi rear is what is listed in the shop manual.
    and yes. I have a very heavy throttle hand. in my own defense, it's so much fun!
  4. sunofwolf
    sunofwolf New Member
    that's too much air-I use 33 front and 35.5 back, maybe 33.5 front too or 36 rear -unless I were to load it up with hard bags. I wonder if the pr4 gt tire for heavy bikes might work on the vfr or be too stiff? Loaded up I would bet the gt would be better. That's not very good mileage for a touring tire- but you roasted it with being way to hard on it:snowman:
  5. HellFishTat
    Raleigh, NC
    I am fat 225, and I ride with Givi E360's panniers and a V46 top case all the time. I carry rain gear, multi meter, spare chain and extra gloves always. Obviously, the extra chain is the heaviest extra, but I don't want to need it, and not have it.
  6. OOTV
    OOTV Member
    Ok, that might help explain things a bit more. :wink:
