3rd Generation VFR 1990 - 1993
Discussion in 'Specifications' started by WhiteKnight, Jun 22, 2006.
  1. WhiteKnight
    WhiteKnight Well-Known Member
    London, Ky
    Dimensions:
    Length: 85.8 in. (2,180 mm)
    Width: 27.6 in. (700 mm)
    Height: 46.7 in. (1,185 mm)
    Wheelbase: 57.9 in. (1,470 mm)
    Seat height: 31.5 in. (800 mm)
    Footpeg height: 13.3 in. (338 mm)
    Ground CLearance: 5.1 in. (130 mm)
    Dry weight: 476 lbs (216 kg)
    Curb weight: 529 lbs (240 kg)
    Maximum weight capacity: 417 lbs (189 kg)
    Engine and Transmission:
    Displacement: 45.64 ci (748 cc)
    Engine Type: Liquid-cooled V4
    Stroke: 4
    Compression Ratio: 11.0:1
    HP: 103 (75.2 KW) @ 10,000 RPM
    Torque: 56.4 ft.lbs (76.49 Nm) @ 8000 RPM
    Valves per cylinder: 4
    Transmission: 6-speed
    Frame:
    Front suspension: Telescopic fork
    Front wheel travel: 5.5 in (140 mm)
    Rear suspension: Prolink
    Rear whell travel: 5.1 in (130 mm)
    Tire Size:
    Front: 120/70 VR17 - V250, 120/70 ZR17
    Rear: 170/60/ VR17 - V250, 170/60 ZR17
    Fuel Capacity: 5.0 US Gallons (19. litres)
    Fuel Reserve: .92 US Gallons (3.5 litres)
    Brakes:
    Front: Dual disc
    Rear: Single Disc
    Colors:
    1993: Pearl Crystal White
    1992: Granite Blue Metalic
    1991: Italian Red
    1990: Italian Red
  2. fisch
    fisch New Member
    4th gen
    Whatever happened to putting the specs for the 94-97.
  3. WhiteKnight
    London, Ky
    I don't have the specs for the 4th gen. I will work on seeing if I can get some to post.
  4. neptun750
    neptun750 New Member
    California
    Don't for get to add Pearl Black like my 1992:)
  5. WhiteKnight
    London, Ky
    The color is actually a blue, but it does look black. I replaced a busted left mid cowl on my 93 with a new one from a 92. It says its a Granite Blue Metalic, but I swear it looks black.
  6. neptun750
    California
    Interesting, I just took off my entire front faring assembly to get at my spark plugs, and I noticed the backs were blue in color...But under my saddle there is a sticker with the color code which reads Pearl Black 0620 or something like that. I m thinking Honda used the darker color farings and sprayed over.
  7. neptun750
    California
    Ok, here we go...the black color is a combination of two colors read this:
    1992 VFR750F (RC36) Overview: No major changes except cosmetics. U.S. Honda went to black with purple/silver stripes and silver wheels (actually the black is a really, really dark green with a black flip-flop translucent coat and blue pearl on top of that).
    I really love this color on my bike...But I had to remove the odd purple decals. Looks much better I think.. Cheers
  8. itachi
    itachi New Member
    Durban
    I'm getting a VFR400 NC30
    is there anything i should look out for?
    i'm getting it as my first bike, would that be a good choice?
  9. betarace
    betarace New Member
    Middleburg, VA
    Granite Blue Metallic
    Just repainted my '92 using OEM colors, and the color is officially Granite Blue Metallic. Most folks think it's black, but when you get it in the sun and look from the right angle, there is some "blue tinted" metalflake in the black.
  10. neptun750
    California
    Hey Betarace- Are you tracking your VFR? How is that? I am thinking about trying to get started. What should I be prepared for? What do I need besides money?
  11. TAGLICIOUS
    TAGLICIOUS New Member
    Coeur d'Alene, Idaho
    4th gen... neh
    The body (plastics) and the styling is just off. My personal opinion.
    Also. I think they screwed the pooch in '02 with styling... just bugs me. so f'n ugly. :bootyshake2: (lol) I could be wrong with that though... it's happened a time or two :ncb:
  12. Trize007
    Trize007 New Member
    Smyrna, GA
    My 93 is blk with silver decal with purple stripes. The purple is gay as hell... I am about to sand all of it down and primer it to get ride of the purple junk.
  13. betarace
    betarace New Member
    Middleburg, VA
  14. 92yellowveefer
    92yellowveefer New Member
    Hingham, MA (south of Boston)
    Mine was originally black/blue as well; too many idiots refused to see or hear me.
    thus the Corvette Competition Yellow with the 2Bros full system...
    Problem solved.
  15. PhotosByHamza
    PhotosByHamza New Member
    Westchester, NY
    Fairings for 3rd Gen?
    Where can I get Replacement Fairings for my 1993 3rd Gen VFR750F?
    Also, where can I get a 2 Brothers Full exhaust?
  16. betarace
    betarace New Member
    Middleburg, VA
  17. 92yellowveefer
    If you're looking for stock, you can always go up and order through Ron Ayers Motorsports (Ron Ayers Motorsports - Motorcycle, ATV, Jet Ski and Generators Parts and Accessories). Locate the online fiche under "OEM Parts" for the 90-93 / 3rd gen and drill down into body work. Not cheap, but guaranteed to be the absolute best fit and quality - direct from Honda. There are some other vendors who are making aftermarket even for the 3rd gen - do a search through the forums - someone posted on this very subject fairly recently. But there may be some retro-fit work associated with that.
    Good luck - let us know how it tunrs out.
  18. Rev
    Rev New Member
    Olympia,WA
    Get stock fairings from Service Honda; better prices for OEM than Ron Ayers.
    As for the 2Bros full, good luck with that. Due to their age, all I've seen are slip-ons. You might have luck with ebay though.
  19. 92yellowveefer
    I have a full 2Bros C2 system on my '92, but I bought it direct from them 12 years ago. They dropped the third gen VFRs completely five or more years ago it seems.
    I think eBay is your only bet, unless you can find one off a salvage somewhere. Good luck
  20. PhotosByHamza
    Westchester, NY
    Wanna sell me yours with my stock as trade?
    Come on you know you do, my stock is in perfect condition...
    :biggrin:
