3rd gen solo seat cowl question
Discussion in '3rd & 4th Generation 1990-1997' started by dasundqu, Apr 18, 2013.
  1. dasundqu
    dasundqu New Member
    duluth, MN
    so i purchased a solo seat cowl from airtech streamlining and was test fitting it before prep and paint. im just wondering how it stays on the bike. do i need to drill holes for the metal nobbies to go through or does the little clamp behind the nobbies hold it? also, has anyone purchased a solo seat cowl from airtech and how did they like it.
    thanks
    oh its a 91 vfr750
  2. dasundqu
    dasundqu New Member
    duluth, MN
    Really? No one knows?
  3. rjgti
    rjgti New Member
    regina sk
    you have to drill it and those side screws go through it to hold it on
  4. safetypro10
    safetypro10 New Member
    Dallas, TX
    Place the cowl on the bike and press in place for a minimal gap. Put a pencil ionto the hole and scribe a hole/ Drill clearance for the 6mm bolt with the ferrule over it, probably about 8mm (.323). Be very careful and go slowly so you don't bust rhe gel coat. Mounts in the back first and than down into the sides. I don't belive the Airtech unit is made for the pad. Probably have to fab up something.
    Write up and pics required.
    Larry
