2nd Gen VFR750 front sprocket +1
Discussion in '1st & 2nd Generation 1983-1989' started by slowbird, Feb 5, 2011.
  1. slowbird
    slowbird Member
    Toronto, Ontario.
    I'm thinking of going +1 on the front sprocket of my 1986 VFR750.
    When I went +1 on my VF500 the chain interfered with the sprocket cover ever so slightly....I'm wondering if the same thing will happen with my VFR.
    Has anyone gone +1 on the front of their 2nd Gen?
    Why, Matt ?? Trying to save petrol ?? Shift up earlier.
    With a 6th gear to use to reduce rpms, there's not much point to +1
    And your bike will be slower to accelerate in every gear, like neutering your cat.
  3. slowbird
    slowbird Member
    Toronto, Ontario.
    I'm looking for a bit better Fuel Economy.
    I use the bike for riding to work and weekend cruises...not worried about killing the acceleration of the bike.
    It has more than enough gusto as it is.
  4. TOE CUTTER
    I would say negative on going up, it has a hard enough time turning in 6th gear as it is.
  5. slowbird
    slowbird Member
    Toronto, Ontario.
    Can you explain what you mean exactly, plz?
  6. TOE CUTTER
    In 6th gear the engine is really struggling past aboot 9k RPM. A taller sprocket is gonna make it worse and at legal highway speeds your RPM's are going to be low .
  7. slowbird
    slowbird Member
    Toronto, Ontario.
    Hmmm....I didn't think the hwy speeds were that low...but it has been awhile.
    I'll toss on an old 44 rear sprocket from my old VF500 and see how it goes this season.
    Thanks Toe, and SM.
  8. Pcohen
    Pcohen New Member
    jonesboro, arkansas
    +1 on the front might lower your rpm's while crusing but it will kill your gas mileage during acceleration
