1st electrical issue w/ my '06 6th gen.
Discussion in 'Mechanics Garage' started by JTC, Feb 4, 2015.
  1. JTC
    JTC New Member
    Watts, CA
    New 04:58 JTC
    ...and license plate light is oot again. Been over every fuse & relay I can think of, and nothing... WTF. But it can't be nothing??? oh and 2 leds in my tail light are oot too.
    Edit
    New 04:56 JTC
    F'it whatever, I'll worry aboot it when I get home. Turn on my heated grips as i got on the freeway. Speedo shoots up 166,184,198,244,333, then goes back to what appears normal. heated grips never come on.
    Edit
    New 04:54 JTC
    is oot.
    Edit
    New 04:54 JTC
    anyway, found a "spike" splicer floating around loose & found the spot on the license plate light where it was tapped in at. Put it back, light came on, went to work, ALL Good. NOPE! As I started her up, immediately I notice my voltage indicator light
    Edit
    New 04:49 JTC
    license plate light went oot, and its not the bulb or fuse. Power coming in at the plug.
    Edit
    New 04:48 JTC
    btw, what's up Randy, TC, ridervfr & B?
    Edit
    New 04:47 JTC
    spent over an hour reading through threads using the search feature, & I know I've seen it addressed before. Should I go ahead start a new thread anyway?
  2. NormK
    NormK New Member
    For starters have you checked your connectors from the stator to the rec/reg, when these go bad all sorts of weird things happen, check what voltage the alternator is putting out.It may not be this but it needs checking regardless of your current problems
  3. JTC
    JTC New Member
    Watts, CA
    Bike Sat 6 morning while I was, er , um, on vacation... All good
