1985 vfr
Discussion in '1st & 2nd Generation 1983-1989' started by kdhvac, Dec 16, 2014.
  1. kdhvac
    kdhvac New Member
    IMG_20141130_155710_833.jpg 1985 in progress
    Not quite ! :eagerness: First VFR's in 1986, a big improvement.
  3. kdhvac
    kdhvac New Member
    not sure what to do with carb ports , plastic tee's that connect carbs together . repair book not showing these ports . may have to do with vents for pollution ?
  4. squirrelman
    Larger tubes are fuel tubes, smaller are carb air vents.
  5. kdhvac
    kdhvac New Member
    still hard starting . not sure if carb jets are correct , I used carb off of 1985 motor because it was in better shape but turns out my running motor is a 1986.
