1985 vf500f - valve cover gaskets
Discussion in '1st & 2nd Generation 1983-1989' started by LDN_PDX, Jun 5, 2020.
Tags:
  1. LDN_PDX
    LDN_PDX New Member
    Missing the most essential parts... the valve cover bolt grommets that are actually responsible for applying the pressure to prevent the valve covers from leaking.
  3. LDN_PDX
    LDN_PDX New Member
    god damn it, what do these parts look like? well guess i gotta find these before i begin thank you for letting me know.
  5. LDN_PDX
    LDN_PDX New Member
  6. LDN_PDX
    LDN_PDX New Member
    thank you, ordering now.
    Those are generic. Hopefully they will apply the correct pressure. Probably be fine. Hardly anybody replaces them because they are expensive from Honda, $8 ea. Then their valve cover still leaks, they try and over-tighten a shouldered bolt and... snap.
  8. Colddevil
    Colddevil Member
    Wisconsin
    Thanks. Just got to relive that. This was the experience that got me to invest in a 1/4" torque wrench.
  9. LDN_PDX
    LDN_PDX New Member
    what is the correct pressure for these? i still have not located a manual yet.
  10. Colddevil
    Colddevil Member
    Wisconsin
    Clymer manual says 6-9ft*lb for "Cylinder Head Cover"
    LDN_PDX likes this.
  11. NorcalBoy
    Honda engine covers, universally, are 7 lb/ft, or 84 in/lbs. Honda standard torque for 6mm bolt.
  12. Jim McCulloch
    Jim McCulloch New Member
    Those are the gaskets I have had a ton of trouble with. Good price but the head gaskets don't fit without modifications. BUYER BEWARE!
  13. raYzerman
    raYzerman Member
    Millgrove, ON
    Once a shoulder bolt bottoms, you're finished... crank all you want and it won't fix anything. You are relying on the thickness of those rubber grommets to hold the cover on and seal.
