Does anyone have the appropriate a/m part number for a 17t gen 1 700/750 front cog. I have bought 2 sprockets from separate places both wrong After partzilla sent me a 1529-17 which isn't large enough to fit over the output shaft. I talked to their tech and he looked for about 10mins. and couldn't come up with the right sprocket. Ordered from a different vendor who sent me a 1521-17 also listed to fit the vf700/750f. It was identical to the first except it actually had the bolt holes for the support for the front most link plates. They are clueless as well. If someone has a known good source for the 17t sprocket to fit the gen one 700/750. The correct part number. Or even a lightly used 17t sprocket and possibly the chain support that bolts on the front as I suspect the 17t is larger, that I could get or even swap my fairly new 16t for. I am about to pull my hair out over this I am looking at 6850rpm at 80mph on the freeway and must have at least the 17t front and probably a 33t rear to get it to where I want it. Thanks in advance db
