08 CBR 600rr instrument gauge cluster on my 95 VFR750
Discussion in '3rd & 4th Generation 1990-1997' started by erbilabuc, Oct 11, 2013.
  1. erbilabuc
    erbilabuc New Member
    After tearing my bike apart there was no way I could go back to the big factory gauge cluster. Its pretty simple wiring. As a heads up there are about 4 wires on the cbr that do not get used and about 6 on the VFR that do not get use.
    Gas gauge works but its off by about 50% so when it says that my gas is at half; it really is empty. Speedometer is off by a lot but I think a speedohealer will fix that. The coolant temp is also off but I have a plan for that and will update if it works.
    tach works and all indicator lights work perfectly
    CBR to VFR
    pink/green to pink = speedometer
    violet to black/brown stripe with 1 dot
    brown/ black stripe with 1 dot to grey / black stripe
    grey with red stripe to green with blue stripe = coolant temp
    white with black stripe to brown with white stripe
    blue with red stripe to blue with red stripe
    light blue to light blue
    green to green
    green with black stripe to green with black stripe
    yellow with green stripe to yellow with green stripe
  2. Scubalong
    You are a MAD man Sir :crazy: I like it :thumb:
    Not sure if I want to go through all the trouble. My hat out to you Sir
  3. erbilabuc
    thanks. Used the ECT sensor with plug off an 09 cbr600rr. Pretty simple and you only need to use the grey with red stripe wire and wire it to the factory wire. THe other 2 wires just cap them off. Now the coolant gauge works.
  4. VT Viffer
    VT Viffer New Member
    South Carolina
    17k tachometer... :bounce::bounce:
  5. erbilabuc
    yeah im lucky when I get even half way to that
