'06 now with GP Shift
Discussion in 'Mechanics Garage' started by junktionfet, Sep 29, 2009.
  1. junktionfet
    junktionfet New Member
    Raleigh, NC
    I've reached a point where I need GP shift (reverse pattern) on my RC51 track bike. In order to get accustomed to it, I need it on my street bike. Trouble is though, no one seems to make a GP Shift kit for the VFR.
    I took a CBR954 rearset, gave it some heat to open up the mounting points slightly. Then I took a stepped bit and made the bolt holes slightly larger. In order for the rearset to clear the swingarm, I stacked two washers per bolt behind the rearset to act as spacers.
    I bolted everything up and adjusted the shifter. It's tight for sure--just touches the bodywork when shifting, and the shift rod itself touches the kickstand spring, but nothing binds.
    :thumbsup:
  2. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    huh... thats cool.
    why do you NEED it on your track bike?
  3. junktionfet
    Raleigh, NC
    The fear of feeling the ground tug at my Sidi boot again while preparing for an upshift around a sweeping turn. Harmless or not, I don't like it--it holds me back, messes with my head.
    And as a matter of principle, reverse shift makes a lot more sense. I only downshift when the bike is pretty much vertical, and getting my foot under the shifter while braking is easier than when accelerating.
  4. 02 VFR Rider
    02 VFR Rider New Member
    yes It sucks when you get your foot stuck under the shifter in mid corner.
    thanks for the info, has to be cheaper then buy'n a sato rear set.
  5. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    yeah that does make a lot of sense. thanks bro:thumbsup:
  6. bat-stang
    bat-stang New Member
    H-Town Texas
    I would love to do a reverse pattern on my 5th gen... Had one on my old CBR600RR, wished i didn't have to go back...
  7. 02 VFR Rider
    best to put sticker on bike that says GP shift.
    It sucks when you forget and shift the wrong way, it takes a bit to get used to it.
  8. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    i always thought about it, but always forget to ask? how fucking tall are you?
    im 5'11" and had to drop mine and inch to flat foot, i cant believe you actually raised your's....:eek:
  9. Bubba Zanetti
    Bubba Zanetti Member
    Delaware
    I know a buddy who's going to do this on his street bike for the same reasons.
    Interesting...
    BZ
  10. CandyRedRC46
    CandyRedRC46 Member
    Orlando Florida
    i could understand if my bike was a track bike id be all for it. but mines a dayly driver, so backing up and turning around every day in a gravel driveway, not a good idea to be on my tiptoes... plus the added stability doesnt hurt either...
