Ok. The first time it started running rough (stumbling, kept dieing), I drained the gas and got some from another gas station. Everthing was well. Now she's doing it again. Run rough two mornings in a row. This morning she started stumbling bad while I was in 2nd of 3rd going in slow traffic and she died twice. Had to keep on the throttle to keep her alive. She's garage kepted, K&N filter, scorpion exhuast, and everything else is stock. I never could get a code last time. It would just blink non-stop. Heading home from work today the "FI" light would flutter a tad when I blipped the throttle and so I reved it and it stayed on. The light stayed on all the way to my bank which is around 13 miles away. Came back out and started her, light went off. WTF!!!!!! She never runs rough in the evening. I always let the temp warm up to at least 125F or more before taking off. I'm gonna go see if I can get a code now.
sounds a bit like starter valve,they may need setting up? if you have a good honda dealer/garage near you, I would get someone to do this, unless you can do the job yourself,it's most definatly worth a try. Or it could be the fuel pressure regulators????
